The trouble with that kind of coolers is that because the fins are so thin, when we start working on them they bend, and you have to have a steady hand when working.
Another consideration would be making a block from this type of cooler:
Akasa  AK-350 with 225 copper pins and a 5mm thick baseplate.
Dimensions: 60x60mm
Message édité par Jag le vendredi 19 novembre 2004 à 20:13:20
