Repairing of Prometeia mach 1, Vapochill LS and LD unit
piotres
jeudi 15 mars 2012 à 04:10:35
Hello
Currently I work over repairing 3 single-stages units:
-vapochill LS
-Prommie mach 1
-LD unit.
Each have been incomplete and/or damaged .
Units were not good packed for shipping .
Vapo LS (the strongest damage :eek:), LD SS and Mach 1.
Mach 1 has been without suction line.
I've started with Prommie
I've removed stock electric.
More pictures soon .
Regards
Peter
jeudi 15 mars 2012 à 11:00:59
Hello Piotres,
A lot of work to be done on those SS.
Looks like people go to war with them
piotres
vendredi 16 mars 2012 à 04:10:11
yes , You're right :-S.
Prommie Mach 1 in progress :
Fresh oil.
Case will be black now .
New suction line by me - braided flex + 42mm steeper.
And some first run in cold workshop :
Finaly it'll run much warmer .
vendredi 16 mars 2012 à 11:08:23
Did you make some test with load ?
piotres
dimanche 18 mars 2012 à 11:18:06
Yes, tested it with 280W, approx -30*C with that load .
LD unit before mod.
New black paint . Not powdercoat, just cheap homemade wet acrylic paint.
Leak testing with nitrogen in water .
Holddown must have been moded because I had only versions for 42/54mm evaps, and that one is 38mm.
Also MUCH bigger condenser. New drier, added shrader valve on discharge side.
to sum up .
BEFORE:
AFTER:
piotres
dimanche 01 avril 2012 à 10:05:31
Now Vapochill LS:
Case has been heavy damaged, so I decide to remove it ...
+remove whole stock electric.
and scrap it ..
That's amount of oil which I've poured from compressor :-O - approx 20 ml.
And that's suggusted amount of new oil.
Now that will be just benching unit on baseplate .
First time I soft-solder captube to accumulator - and I've loved that work .
Pressure testing of whole unit together .
Regards
Peter
dimanche 01 avril 2012 à 10:19:09
Testing a whole circuit in a bath ... You're definitely the only person that I know doing that
piotres
dimanche 08 avril 2012 à 00:48:41
"vapochill LS" has been finished and loadtested :
Final unloaded temperature.
Final 315W load temperature.
We decided to change evap in "unit with LD case"- old wasn't flat .
Plus suction line will be much longer now. Second suction line for another unit (CPU+GPU ).
piotres
mardi 04 septembre 2012 à 01:16:37
I have finished all of them a LONG time ago, but I haven't got much time to upload pictures....but here are them :
"LD" unit before mod:
"LD" unit after mod:
Temperature under 315W dummyload:
Prometeia before mod:
Prometeia after mod:
All 3 units before mod:
All 3 units after mod:
I hope that You like them :yepp: :.
Regards
Peter
mardi 04 septembre 2012 à 09:18:20
Nice
